Anyone have a good idea for Testing for Gearbox/Water Pump leaks on a 81 SRX or 540 Vmax motor? Anyway to put 1 to 2 lbs of Air Presuure in the box and see if it leaks down?
Mark
Testing for Gearbox/Water Pump leaks???
Re: Testing for Gearbox/Water Pump leaks???
Mark.. This is one of the way's I check them, it may not be the best but I think it is a very simple way. If the engine runs let it cool down and if you have pressure at the radiator cap then you probably have a good none leaking seal. if it leaks by the seal the pressure will just escape out the gear case some where. You can also remove the cap and use a automotive radiator tester and pump it up to about 8-10 lbs, if the pressure drops after about a minute or so then you have a leak some where, look and listen and you can usually find it especially on the 84-up as they have two drain holes in the bottom of the gear case for the anti freeze to escape and not dump into the gear case. Hope this helps you out..
Did not know that !vmax-540 wrote:Mark.. the 84-up as they have two drain holes in the bottom of the gear case for the anti freeze to escape and not dump into the gear case.
