81 SRX with 38mm carbs?
Posted: Sun Sep 30, 2012 2:57 am
by vintsrx
Hey Guys!
I was just wondering as to what is a good carb spec. to start tuning a set of 38mm non-power jet carbs might be. Am currently running 340 mains, 3.0 slides, can't remember pilots--I think 45's, 6DH4 needle in leanest setting. Seems to run OK, but performance falls off once it warms up, so suspecting being too lean on bottom end?
Re: 81 SRX with 38mm carbs?
Posted: Wed Dec 12, 2012 4:56 am
by vintsrx
Hey Guys,
Just thought I'd try again if anybody knows a good carb setup on a 81 SRX using 38mm round slides with NO power jet?
Posted: Wed Dec 12, 2012 9:08 am
i have always heard that when you put carbs from a vmax on a srx you can start with stock vmax settings. so therefore i would think you could start with non-power jet settings from a vmax. whether or not you can find some specs on non-power jet 38's for a vmax i dont know. a search may turn something up, otherwise maybe someone running non-power jets on a vmax will chime in
