I am looking to use a 203800A clutch. It comes with an oil seal on the back side. Can I just remove this seal and use the clutch? WIll there be any other changes I need to make to the clutch?
102C Clutch with rear oil seal
Re: 102C Clutch with rear oil seal
Good question, is it a 30mm Shallow Tapered Bore ?
viewtopic.php?f=2&t=1529&p=5633#p5633
-Clutching
http://www.hiperf.com/acatalog/cometcalguide.pdf
Comet Clutch, Spring 8U9-17643-10
http://www.vintagevmax.com/vvforum/view ... =5513#5513
Yamaha V-Max--30mm Shallow Tapered Bore Code: 217506
(Fits `83-87 V-Max, `81 SRX) This clutch comes set up for 1-1/4 belt width.
http://www.psep.biz/store/yamaha_snowmo ... _parts.htm
http://www.vintagevmax.com/vvforum/view ... hlight=102
http://www.snowtechmagazine.com/article ... epower.php
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
-Clutching
Yeah it is one fo the clutches listed in the 102 vs 108 thread. Teh only difference stated is where the taper starts (.140 vs .245), so as long as the seal is not an issue you should just sapce teh secondary out .105, assuming that is OK.
OK I picked up a clutch with the seal (the one in the 102 vs 108 links 208300A). It looks like it will work just fine, I think the seal will not matter at all. I did talk with Don at CPC (the saem Don that used to work at Comet), he said you can simpli unscrwew the seal, but I don;t even think it matters. I just need to reset the offset.
