Pimp Drive gear oil/water seal
Guest
Post by Guest »
I'm looking for an oil/water seal for the pump drive gear on my 83 Vmax. Everywhere I look it is not available or backordered. Can anyone help or give me direction to where I can get one.
http://www.highlandsyamaha.com/parts.aspx Part #3[/img]
Donnie
Post by Donnie »
Which gasket are you trying to find? I went to the link you gave and it started me out in the brakes category. I can use the link if you telling me which category to look under to see which #3 part you were looking at. I have a few gaskets left over from an engine build. I may have the one you need.
Donnie
Donald L. Gilbert, Jr.
1983 Yamaha Vmax
1986 Yamaha Vmax
From Yamaha's own site take a look at the 87 Vmax schematic the seal is different 93103-25146-00 OIL SEAL, SW-TYPE I ordered and recieved one this summer. Maybe you can switch over to the newer style ?
Guest
Post by Guest »
Donnie wrote:Which gasket are you trying to find? I went to the link you gave and it started me out in the brakes category. I can use the link if you telling me which category to look under to see which #3 part you were looking at. I have a few gaskets left over from an engine build. I may have the one you need.
Donnie
It's part #3 in the Pump drive gear section
Donnie
Post by Donnie »
I was looking at the picture you were talking about but I think #3 is pointing to a bearing. Are you looking for #27 ???
DonnieImage
1983 Yamaha Vmax
1986 Yamaha Vmax
Guest
Post by Guest »
Donnie wrote:I was looking at the picture you were talking about but I think #3 is pointing to a bearing. Are you looking for #27 ???
DonnieImage
#2 is a bearing. #3 is a seal. #27 is a gasket.
I need #3. Look on the chart that references #3. It is an oil seal.
Donnie
Post by Donnie »
OK, I see. I thought there was a bearing on both sides. I don't have that seal. Sorry.
Donnie
1983 Yamaha Vmax
1986 Yamaha Vmax
