My Future Build Brainstorm
Posted: Tue Jan 26, 2010 3:27 pm
This is just a spur of the moment idea i have.... im going to keep revising this as i change my mind... you guys can let me know what you think of my ideas....
MOST IMPORTANTLY: MY GOAL!! To be trail rideable but also have enough power to weight + "controlability" to SMOKE newer 600cc powervalved sleds in the open fields and icey roads....
Chassis:first off im going to widen out the where my 84 is now... around 42 inches i believe
im going to "swiss cheese" the front frame rails... this loses a little weight and adds a TON of accessibility
all plastic belly pan (mostly because the one i have is junk)
Electrical:
im going to relocated the cdi probably behind the chaincase
auber dual digital egt guages (steal these from my current 84)
led taillight
find a better headlight bulb
Brakes:
i'd like to add hydraulic brakes
Drivetrain:
1" lug track of some sorts
(96) 1.25" studs (may have to drop the suspension down for this)
HIGHER chaincase gearing
Front Suspension:
USI ss railer skis, 6 inch carbide from bergstrom
possibly long travel front struts...
Clutching:
p-85 primary clutch
secondary to be determined... possibly (newer) yamaha to fit the standard jackshaft
Other:
single fuel pump, single pulse line...
stock oil system
i notice i didnt even get into the motor itself... thats is still up in the air in sooo many ways... one thing for sure... it will NOT be stock... at the least it will have updated porting
Electrical:
led taillight
Brakes:
Drivetrain:
Front Suspension:
Clutching:
p-85 primary clutch
Other:
stock oil system
