VooDoo Max
Well. thank God for Holidays. Got the Pol. Xtra 10 in. It sits and feels like my SRV even tho I mounted it different hoping to get some presure of the skis. Set up the scales to measule ft/ rear weight. Got the SRV done,(490 lbs) then suddenly it occured the VM engine is sittingon the bench, guess we'll do that later
Also a few pic's of the porting so far, have everything roughed in, have to go by someone with special tools to get into the back transfers, maybe tomorrow.
Hey, I go anyway. Never had a Pol,but its an easy fit. Don't know anything about the skid that came on the VM either. On the one that came with mine, the shocks were shot. I like good shocks, not sure if any of the good rebuild able shocks are made to fit the VM. I got this for 97 bucks with just rebuilt fox's, couldn't buy 1 good shock for that.
My SRV is a '81, that was before the sus. that are just like the VM that started in '83 SRV's. The XTRA 10 made a big difference in there, so now their twins.
Wel'' se how she rides in a month.
Not bad at all, its a common swap on SRV's and there are diagrams over on Sasha's site. Basically on the Pol skid, all I did was shorten up each of the 4 mounting shafts by 3/16. The only thing to watch here is that both the inner shafts are slightly longer then the outer shafts that are welded on to the skid. I did those on the lathe and made them so they had 1/8 hanging out on each end. You could use a GOOD cut off where also just keep it square. These are the solid Alum. bars the bolts threads into. These get mounted tight to the tunnel and the hollow steel bars in the skid rotate on them as they move, you don't want binding against the sides of the tunnel. Took me just over an hour even with 10 brakes to smoke.
If your tunnel is the same as a '83, I can measure out the mounting hole locations. I re used the rear L bracked, just cut off the rivets and moved forward 2 1/4 in. I made new brackets for the front, basicly sq, flat plates with a notch to clear the steel plate by the foot rests. Be sure to use STEEL rivets not alum to mount these.
I originally was going to use a A/C skid, could have been made to work, but would have taken alot more work to narrow it up because of its design, ( rear torque arms)
did i miss something? what motor is that?
Ok, I was just testin to see if anyone is really looking at this
Its one of the Rotax's out of the drag sled. I didn't think it would fit because rotary valve engines mount the carbs so low. Really, it looks like it wouldn't take much to get it in, even with big pipes.
Ok back to the real project (not that someday this might not happen) I took the VM engine out to a friend. 20 years ago he used to race 535's in a laydown chassis, now he builds engines for the USSA oval racers.. we degreed the ports, he figures it opens way to soon, I think he's right, but I had to go that far to clean the mess up. It still is a hair under the update porting numbers. I'd like to find another set of cyl's but I'm out of time. My only chance to get up north and ride is durring Deckers race week. We have a week of kart racing between Xmas and NY's and still have 3 more of those to build. Guess its going together the way it is
Maybe in summer, now he doesn't want to even touch mine. He's like us with the 120 sleds, the season starts in a few weeks. He has engines and tube chassis everywhere that have to be on the track in a few weeks.
I guess I'm happy that we work on race stuff for a living, I love it., but when its year around, you never get your own stuff done. We never get a weekend off because we have to take care of customers at races
