16mm x 1.5 bolt
Raffus
16mm x 1.5 bolt
Post by Raffus »
Does anyone know where to buy a bolt with these threads to make a clutch puller. I have a Sheldon lathe so I can drill it and make a push pin. I can't find a metric bolt like that any where
jcwineman
Re: 16mm x 1.5 bolt
Post by jcwineman »
Ive found if you fill the hole with trans fluid and wrap the threads with alot of teflon tape it works really good on some applications and you dont have to touch the crank. check u-tube for video. if fastenal dont have a bolt check mac, matco or snap on for some puller shaft specs. thats what i used.
