Complete stock top end for 1981 SRX 440. This came off a sled I bought that was stuck do to a rusty water/oil pump drive gearcase caused from sitting with a bad water pump seal. The inside of the crankcase was clean and sled had a little over 1100 miles on it.
The chrome cylinders, pistons and head are in good shape. All stock OEM Yamaha and never messed with or burned down. The wristpins, bearings, circlips and original rings are in/on the pistons and still good. The pistons have been marked to the bores they were run with. Will come with an NOS set of 8M6 rings and a new aftermarket top end gasket set.
$300 + shipping buys everything. I prefer paypal if not US Postal Money order only . I can, have and will ship world wide.
I will ship via UPS or USPS (your choice). If you want to calculate the cost yourself here are the box measurements and weight.
Figure 17 lbs with box and packing. Box will be 12" X 12" X 12".
Will be shipped from Burlington Wi 53105 USA.
I am cleaning out/off my shelves and do have many other part/pieces for the 81 SRX and 83-87 Vmax 540's.
To many projects, not enough time, need to make room.
Call Phil at 262-716-3368.
